Cpu overclock cooler not hot
Cold is good but is it even under load, also check the actual tenpatures rather then going by feel.
CPU:R9 3900x@4.5Ghz RAM:Vengeance Pro LPX @ 3200mhz MOBO:MSI Tomohawk B350 GPU:PNY GTX 1080 XLR8
DRIVES:500GB Samsung 970 Pro + Patriot Blast 480GB x2 + 12tb RAID10 NAS
MONITORS:Pixio PX329 32inch 1440p 165hz, LG 34UM68-p 1080p 75hz
Yes, that's normal. If it's hot, it usually means there isn't enough airflow carrying the heat away.
Under full 100% stress test it goes to max 60 degree with a pretty big over clock. It''s soo weird it doesnt even feel hot
6 minutes ago, The321 said:
Yeah but you would atleast expect it to heat up the heatpipes a bit
Yes, but only a bit.
