Please help, I kinda screwed up....
Solved by mariushm,
It would be best if you take the laptop to a service place (even one that repairs phones or smaller things) to desolder those damaged parts at the very least.
There's a high probability the damaged parts are identical to the ones on the right in the picture, and in parallel ... if they're capacitors, having more in parallel increases capacitance. A phone repair place won't have such big capacitors, but at least if you remove the parts you won't risk them causing further damage (if the capacitor is broken in half, vibrations, shock could move the parts in such a way that eventually they'll connect again which could show up as a short circuit and trip the power supply or the battery)
