I am looking to build a PC for the first time to see if it is fun.
I have a build that i am confident with, except i don't know what power supply to use.
Like i said this is just to see if i like building PCs, so these specs are low:
CPU: Ryzen 3 2400g - APU
GPU: Vega 11 - APU
SSD: Adata XPG SX6000 128gb
HDD: 2TB Seagate Barracuda
RAM: HyperX Fury DDR4 2666 C15 2x4GB
MBD: Gigabyte GA-B450M DS3H-CF
OTHER: Wraith Stealth Cooler, USBs
What power supply do i need? This PC has bad specs for gaming so if i try to game on it it will probably use a bit more power.
Also i would appreciate other advice like:
1. Are these compatible?
2. Will this case work? https://www.amazon.com/Thermaltake-Versa-Gaming-Compute...
3. Will the Wraith Stealh Cooler + Case be enough to cool everything?
4. Other advice.
I tried the outervision PSU calc but it did not have Vega 11 graphics in its database of GPUs.
Also i don't get extra advice which is nice since this is my first PC build i will be attempting.
Thanks!
-Rage300
https://linustechtips.com/topic/1006626-what-power-supply/
Use pcpartpicker.com to see if things are compatible and see wattage.
a 550w psu will work, BUT make sure you buy a good one. Take a look at this list, I suggest any 550w PSU from tiers S to B
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1006626-what-power-supply/#findComment-12064870
GPU: Vega 11 - APU
4. Other advice.
Thanks!
-Rage300
Budget?
The Louvre
Lian-Li PC-O11 DW   |   ZOTAC RTX 2080   |   Core i5 9600k   |   SeaSonic FOCUS Plus 650W Platinum   |   MSI MPG Z390 Gaming Pro Carbon  |  2x16Gb TRIDENT Z ROYAL  |   2xSX8200 240Gb NVME SSD's  |   1x Seagate Firecuda 1TB   |   EVGA Closed Loop Cooler 280mm   |   1x MSI MPG27C Monitor
https://linustechtips.com/topic/1006626-what-power-supply/#findComment-12064896
GPU: Vega 11 - APU
4. Other advice.
Thanks!
-Rage300
A few things:
1) Yes, they are compatible. But there are a few changes I would make:
 - Get the Ryzen 3 2200G, it's better value for money. You can add a dedicated GPU later when you save up.
- Get DDR4 3000Mhz or more speed RAM. Forget about C15/16. Just get whatever is cheapest for DDR4 3000.
- Get a better motherboard. I can tell that you are on a budget, but there are better motherboards out there. Go for a low end MSI or AsRock B450 motherboard.
2) Yes, that case would work, but it's a little choked for airflow. I would recommend the H15 over the H17, unless you can find H18.
3) Yes. Buy an additional fan if you can.
Here's an optimal build:
CPU: AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor  ($89.00 @ Amazon)
Motherboard: MSI - B450M GAMING PLUS Micro ATX AM4 Motherboard  ($84.99 @ B&H)
Memory: Team - Vulcan 8 GB (2 x 4 GB) DDR4-3000 Memory  ($60.98 @ Newegg)
Storage: ADATA - Ultimate SU800 128 GB 2.5" Solid State Drive  ($28.99 @ Amazon)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Amazon)
Case: Thermaltake - Versa H15 MicroATX Mid Tower Case  ($43.99 @ Amazon)
Power Supply: Corsair - CXM (2015) 450 W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.99 @ Amazon)
Total: $407.93
Generated by PCPartPicker 2018-12-10 14:17 EST-0500
CPU: AMD Ryzen 5 5600X | MOBO: MSI B450 Tomahawk GPU: AMD Radeon RX 6800XT | RAM: GSkill Trident Z DDR4 3600Mhz | PSU: ADATA Core Reactor 850W 80+ Gold | CASE: Fractal Design Meshify C MONITOR: LG 32UL500-W 4K 60Hz, Gigabyte M27Q 1440p 165Hz
https://linustechtips.com/topic/1006626-what-power-supply/#findComment-12064957
Btw, with the build that I mentioned above, you can overclock the Ryzen 3 2200G (message me if you want to know how) to get the same/better performance than the 2400G, which you couldn't have done with your initial build (because of the awful motherboard)
https://linustechtips.com/topic/1006626-what-power-supply/#findComment-12064968
1 hour ago, Rage300 said:
You can remove the GPU if you'd like and add more storage but this is a pretty capable mid tower machine. The 16GB of ram over the 8GB will be a big help.
The Louvre
https://linustechtips.com/topic/1006626-what-power-supply/#findComment-12065089
GPU: Vega 11 - APU
4. Other advice.
Thanks!
-Rage300
I guess you are from the us
in that case, get the corsair CX450
https://linustechtips.com/topic/1006626-what-power-supply/#findComment-12065473
