I haven't done any custom water cooling before and I am buying a 2nd hand 1080 ti sea hawk from MSI. I already have a Corsair H115i for my CPU. My issue is that my case won't fit another 240/280 radiator. Best I could do would be a single 140mm radiator. Not so sure it would be sufficient and that I would get any benefits from having a 1x140 water cooling compared to a factory air cooling on a 1080 ti.
So my idea is to combine the AIO cooling with custom loop for GPU. Would it be possible to run 280mm + 140mm radiators with an extra reservouar and perhaps an extra pump (if needed) in the same loop for both my CPU and GPU?
https://linustechtips.com/topic/1006546-aio-custom-water-cooling/
https://www.ekwb.com/news/ek-mlc-phoenix/
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
1 minute ago, TheNaitsyrk said:
The thing is that the Sea Hawk model already has the water cooling block. And I already have an AIO for my CPU. Instead of getting rid of both and getting a full kit I thought of saving a buck and breaking the AIO loop with an extra radiator and water reservouar for the GPU.
You'll spend the exact same amount of money on the loop, and this has easy maintenance. I am using one.
You can then sell H115i too.
Main PC:
Case: TT P3
HTPC:
3 minutes ago, Moonzy said:
first thing that pops into my mind would be galvanic corrosion, that's a thing
Yeah, or he'll have algae growing in his loop.
Hence why I suggested to get the kit from EK and by selling H115i it'll be a lot cheaper.
https://www.ekfluidgaming.com/ek-kit-a240g
Main PC:
Case: TT P3
HTPC:
I'm not really worried about algae or corrosion as I will be making sure I have the same metals on all ends and will be using proper coolant. My worry is mainly if I open up the AIO I have and add the GPU in the loop. Would my pump manage it and for better cooling effect I would be adding an additional 140mm radiator. Would the AIO pump manage that?
Just sell the h115i, it probably won't work and you shouldn't try it
