So i built this beauty a month or so back but i decided i should share it on here. Specs are as followed
CPU-1700x OC to 4ghz
GPU-gtx 1080 ftw hybrid
MOBO- X470 ASUS PRIME
RAM- 16gb teamforce ddr4-3000 ram
PSU-corsair rm650
CPU COOLER-EVGA 280mm aio
Boot drive-250gb m.2 ssd
Hdd- one 3tb hdd and one 1tb hdd
Let me know what you guys think!
https://linustechtips.com/topic/1006411-my-first-build/
Some red lighting accents contrasting with the overall whitish lighting would look amazing.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
https://linustechtips.com/topic/1006411-my-first-build/#findComment-12062988
Cable management could've been better, but overall great system.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1006411-my-first-build/#findComment-12062993
