So I have put together a Ryzen build I don't plan on going to 4k anytime soon for gaming anyway so here is the build any suggestions would be appreciated.
AMD - Ryzen 5 2600X 3.6 GHz 6-Core Processor
Gigabyte - B450 AORUS PRO WIFI (rev. 1.0) ATX AM4 Motherboard
Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory
Samsung - 970 Evo 250 GB M.2-2280 Solid State Drive
Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive
MSI - Radeon RX 580 8 GB ARMOR MK2 OC Video Card
Deepcool - MATREXX 55 ADD-RGB ATX Mid Tower Case
EVGA - SuperNOVA G3 550 W 80+ Gold Certified Fully-Modular ATX Power Supply
Corsair - Air Series White 2 pack 52.19 CFM 120mm Fan X 2
https://linustechtips.com/topic/1006326-ryzen-1080p-build/
What's your budget and location (country)?
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1006326-ryzen-1080p-build/#findComment-12062285
It looks fine, if you wanna save some cash then I'd swap out that SSD for a sata SSD. Unless you're doing video editing or something where you need to do large file transfers, then go for it.
https://linustechtips.com/topic/1006326-ryzen-1080p-build/#findComment-12062297
That's true I have thought about getting into video editing, but I can always upgrade when I start that.
https://linustechtips.com/topic/1006326-ryzen-1080p-build/#findComment-12062327
https://linustechtips.com/topic/1006326-ryzen-1080p-build/#findComment-12062365
Ryzen 7 is  a better choice.
PCPartPicker part list: https://pcpartpicker.com/list/QXQrXP
Price breakdown by merchant: https://pcpartpicker.com/list/QXQrXP/by_merchant/
CPU: AMD - Ryzen 7 1700 3 GHz 8-Core Processor  ($195.99 @ SuperBiiz)
CPU Cooler: ARCTIC - Freezer 33 eSports ONE (Black/White) CPU Cooler  ($32.07 @ Amazon)
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  ($73.88 @ OutletPC)
Memory: Team - Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory  ($110.88 @ OutletPC)
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive  ($72.00 @ Amazon)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($44.85 @ OutletPC)
Video Card: Asus - GeForce GTX 1070 8 GB Dual Series Video Card  ($334.89 @ OutletPC)
Case: Fractal Design - Meshify C TG ATX Mid Tower Case  ($93.99 @ Amazon)
Power Supply: Corsair - CXM 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.89 @ OutletPC)
Total: $1018.44
Generated by PCPartPicker 2018-12-11 02:02 EST-0500
https://linustechtips.com/topic/1006326-ryzen-1080p-build/#findComment-12067118
