So for picture editing on Adobe do I need a dedicated rig. My current specs. are a 4770K and GTX 660 TI.
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/100615-do-i-need-a-workstation/
Nope.
MSI R9 290 Gaming | MSI Z77 MPower Big Bang | XFX Pro 750W Black Edition | i7-3770k @ 4.5GHz | Corsair H100i | GSkill Ripjaw 2x8Gb | NZXT Phantom 410 Gunmetal | OCZ 128 Gb Vertex 4 | Samsung 250Gb 840 EVO | 1&2 Tb Seagate Barracuda | Logitech G510 | Logitech G700 | Logitech G35 | 3 x LG E2442V
-it24-
https://linustechtips.com/topic/100615-do-i-need-a-workstation/#findComment-1346283
If you have to ask if you need a workstation, you probably don't need a workstation... If you're using your current rig and you're thinking "this is way too slow for the amount of work I do and I need the extra productivity of something better", you probably need a workstation..
Edit: IMO, Unless your job(with a paycheck!) requires you to have the higher productivity(in some situations) of a workstation, the expense of one would be largely unjustified. If you're just doing some editing on your spare time, it makes more sense to save the money..
Just for trolololzing, why is your name "AMD Lover" if you have a 4770K/660ti?
i7 not perfectly stable at 4.4.. #firstworldproblems
https://linustechtips.com/topic/100615-do-i-need-a-workstation/#findComment-1346290
Not really, just get as much RAM as you can and you're good to go. Plenty of HDD space is good too.
not necessary, for editing you will pretty much NEVER use more then 8 gbs. getting 12 or 16gbs of ram is like 2-3 times more then you really need. For an example, i was rendering a video, playing portal, and was afk at a mob spawner in MC and i was using 4.8gbs of ram.
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/100615-do-i-need-a-workstation/#findComment-1346295
I use 4.8gbs on chrome/foobar/steam.
https://linustechtips.com/topic/100615-do-i-need-a-workstation/#findComment-1346380
I use 10gb with just foobar and chrome.
https://linustechtips.com/topic/100615-do-i-need-a-workstation/#findComment-1346395
Well if you have one billion tabs open thats kind of expected :D
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/100615-do-i-need-a-workstation/#findComment-1346409
Dude, I'm hitting my 8Gb limit with a picture I'm drawing right. Multiple layers, you see?
"Fighting for peace is like screwing for virginity"
- George Carlin (1937-2008)
https://linustechtips.com/topic/100615-do-i-need-a-workstation/#findComment-1346414
Do  you have virtual memory disabled? If so, turn it on. If not increase the paging file size. That should help. Then get more memory.
https://linustechtips.com/topic/100615-do-i-need-a-workstation/#findComment-1346586
 Virtual memory isn't disabled. No, I don't particularly need more memory. The image I was working on was kind of special for me. The point I was making was that one can easily go over 8Gb when working in Photoshop. A previous post said that using more than 8Gb was overkill for PS.
I, on the other hand, am a firm believer that with PS you can never have enough memory.
https://linustechtips.com/topic/100615-do-i-need-a-workstation/#findComment-1346724
I, on the other hand, am a firm believer that with PS, you can never have enough memory.
I certainly agree with that.
https://linustechtips.com/topic/100615-do-i-need-a-workstation/#findComment-1346829
7Gb used with modded arma 2 and shadowplay + wow and Chrome and imageboard/YouTube tabs open
Curing shitposts by shitposts
https://linustechtips.com/topic/100615-do-i-need-a-workstation/#findComment-1347553
how?!?! u gotta remember i was using 4.8 WHILE rendering... As im typing this im only at 1.3gb with 4 chrome windows and win media player open. I am going to pu this to the test. imma open like 4 steam games + MC and render and see if i can max out my ram
https://linustechtips.com/topic/100615-do-i-need-a-workstation/#findComment-1348498
those 3 games each use like 1.5gbs then chrome will use like 1 gb too. so that answer seems legit
https://linustechtips.com/topic/100615-do-i-need-a-workstation/#findComment-1348529
As opposed to me using 8gb while in Photoshop? Well dude, whatever, but them the facts.
https://linustechtips.com/topic/100615-do-i-need-a-workstation/#findComment-1350448
