my computer keeps turning off when i try to play games it does not mater what game it is it can be lol or bf4 and it shuts off about 10 to 20 min into the game.I thought that it was my gpu but I sent it in to et it replaced /fixed and that did not fix the problem.My gpu and my cpu are not overclocked and never tried to overclock the are 100% stock.need some help.it wont shut off when doing web browsing and every day stuff.thanks guys
https://linustechtips.com/topic/100606-need-help/
What is the CPU, GPU and power supply. Also what is the CPU cooler/temps during play. Use HW monitor, real temp to see. Look for the max on a gaming session. 62.5C is what AMD says is the max.
CPU:24/7-4770k @ 4.5ghz/4.0 cache @ 1.22V override, 1.776 VCCIN. MB: Z87-G41 PC Mate. Cooling: Hyper 212 evo push/pull. Ram: Gskill Ares 1600 CL9 @ 2133 1.56v 10-12-10-31-T1 150 TRFC. Case: HAF 912 stock fans (no LED crap). HD: Seagate Barracuda 1 TB. Display: Dell S2340M IPS. GPU: Sapphire Tri-x R9 290. PSU:CX600M OS: Win 7 64 bit/Mac OS X Mavericks, dual boot Hackintosh.
https://linustechtips.com/topic/100606-need-help/#findComment-1346141
Your system specifications would be nice to have for us to assess.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/100606-need-help/#findComment-1346144
like drivers ?
Maybe. It could be a bad PSU, or possibly a video card, but the PSU you have with the chip/video card and no OC is fine as far as how much power you need. A bad psu will give you all kinds of problems.
You can try drivers, run malwarebytes in safe mode (press f8 during boot) to eliminate software. If that doesn't work then you can stress test the cpu to eliminate it and the PSU (maybe use something like Asus realbench or Aida to keep temps low if you have no aftermarket fan). Like the other guy said I would try the APU and see if that solves it also.
It could be several things. Finding the problem is done by eliminating stuff one at a time, until only one thing can remain. Power supply is the biggest pain in the butt, cus it can make everything appear to be bad.
I would probably start with eliminating software or try using the APU.
https://linustechtips.com/topic/100606-need-help/#findComment-1346207
LOL.
Looks like you really know AMD CPUs.....
Couple things.
If this happens 10-20 minutes into a game with a pink screen that is usually an indicator of GPU having issues. Chances are if it was a CPU issue and it was getting hot it would either BSOD or just turn off. A pink screen would point me away from the CPU as an issue.
Try putting the GPU into another computer and seeing if the issue follows the GPU. Also make sure to check temps with MSI Afterburner & VRM temp with GPU-Z. Sometimes you will get a faulty card sent back to you.
https://linustechtips.com/topic/100606-need-help/#findComment-1346389
