Hi, i have just stared building my first Xbox 360 slim PC build, i'm sure its not the first time you've seen someone building an Xbox build.  I've done my research on the topic but can seem to find anyone who has done the build using the stock power switch?  I'm trying to keep it as stock as possible from the outside, so that means keeping all the original buttons functional especially the power button.  I'm kind of stuck on how to connect stock power switch to the motherboard, i'm not sure where to begin? Does anyone know how to tackle this problem?
Thanks
Amier
https://linustechtips.com/topic/1005690-xbox-360-slim-pc-case/
Thanks
Amier
Welcome to the Forums!
As long as the switch is a momentary switch you can require it for two dupont leads that are used for hooking it onto the motherboard.
https://linustechtips.com/topic/1005690-xbox-360-slim-pc-case/#findComment-12066719
