overclock MAX POWER LIMIT GPU?
Solved by Cereal5,
The power % slider is only a limit for the power the card can draw. It does not mean the card is actually drawing 140% power target. You can see the power % graph in MSI Afterburner (assuming that is the program you use). As long as temps stay around or under 80C, you can do pretty much whatever you want. NVIDIA cards have built in voltage and temperature limits that make it pretty damn hard to kill just from overclocking.
edit: you only need to stress test for a half an hour or so for GPUs. Maybe an hour or two if you're being extra careful.
