I bought some ram 3000mhz which my motherboard doesn't support, only 3200 and 2666 mhz, i'm wondering if ryzen master will make it run at 3000mhz and run normally without any issues.
motherboard is an ab350m, memory is patriot viper 3000mhz, bought it on sale (the ram, good deal so wasn't thinking about support.)
note: I haven't flashed the bios, as i don't believe there is a need, as i'm overclocking to 3.8 with my 1600 no problems nor would it update memory support.
then try it, BIOS updates can improve memory overclocking.
Desktop benching:
trying to overclock it to near 3000 (2933) fails to post, and i have to jump the cmos.
Is it possible to overclock 3000mhz memory to 3200mhz? I'm new to memory overclocking so I'm not sure.
Mtx turn that on in bios
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
Did you up the voltage? Try 1.35 volts.
out of the box it comes at 1.35v, went up to 3200 just now at 1.375v and insta error code
where would that be in my bios? edit: looked though it all, "mtx" isn't anywhere.
If you can't get 2933 to work then no way would 3200 work.
Desktop benching:
Lol sorry I meant XMP it's in memory menu in Bios
My PC:
My Kids PC:
Just now, Un1verses said:
thought it would as it's listed under supported, worth a shot, because 2666 works, as it's listed
motherboard is just 1 factor, your sticks' capabilities is also one of them.
Desktop benching:
should easily go to 2933, doesn't though. fyi they're 3000mhz, and, the motherboard supports 2666 to 3200 but not 3000 which makes no sense really.
Have you adjusted the timings to be the same as the XMP profile at 3000MHz? Older kits might not have been tested with Ryzen in mind, and Ryzen is more picky to memory sticks compared to Intel
Desktop benching:
it automatically is the same voltage and timings as the xmp profile for 3000, and on the box it ironically says "built for ryzen"
have you updated the BIOS yet?
Desktop benching:
