New power supply
Go to solution Solved by Stefan Payne,
7 hours ago, adyoblu said:
From ur suggested options you can clasify them?
be quiet Straight Power 11
Bitfenix Whisper M
Cougar GX-F/Bitfenix Formula
be quiet Pure Power 10/11
Something like that.
Its 57$ for a reason
https://linustechtips.com/topic/1003531-new-power-supply/#findComment-12037140
12 hours ago, adyoblu said:
Hello,
i have a question. So i saw this power supply and the price is reduced from 100$ to 57$ and i wanna ask if it s worthed Inter-tech argus 650 Watts. If you know a better power supply with 550-650W better under 70 $ you can suggest one.
Inter-Tech is mostly crap, so avoid if possible.
And there are also no reviews (and probably won't be anyway), so I'd avoid it.
The best cheap Gold one is Xilence Performance X...
Other Options:
Bitfenix Formula, Whisper M, be quiet Pure Power 10/11, Straight Power, Cougar GX-F.
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1003531-new-power-supply/#findComment-12039858
Other Options:
https://linustechtips.com/topic/1003531-new-power-supply/#findComment-12041032
Bitfenix Whisper M
https://linustechtips.com/topic/1003531-new-power-supply/#findComment-12042639
