I'm planning on building this PC for Christmas this year. Any thoughts? Suggestions? I want to be able to play games like GTA V, Forza Horizon 4, Battlefield 1 and V, American Truck Simulator, and Fallout 4/76 at 1080p resolution very comfortably. I'm planning on upgrading to a 1440p monitor as well maybe next year. I would buy a GTX 1080Ti, but the prices are outrageous right now. My budget is around $2500. I'm using it for mainly gaming, not really anything else. Maybe CAD from time to time for my engineering class. I plan on running 1 monitor now, but 3 in the future. I do not need to purchase peripherals.
https://linustechtips.com/topic/1003386-first-pc-build/
what the hell happened to that pc part picker list
can you edit that and send it again with the permalink?
Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors
(before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.)
Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors
Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors
Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home
RIP
Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember
Rig 6 (same fate as rig 5) i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember
https://linustechtips.com/topic/1003386-first-pc-build/#findComment-12035775
that doesn't look like that bad of a build. really solid. however the ASUS z390 boards have not been the best boards on the market. other makers did better this generation.
RIP
https://linustechtips.com/topic/1003386-first-pc-build/#findComment-12035794
1 minute ago, DVA said:
Looks solid but my biggest gripes would have to the be $125 paid for the 2..TWO TB Hdd... You could have easily gotten one for $50-60 bucks.
Also the motherboard is definitely ROG taxed, there are better alternatives than that one.
What motherboard would you guys recommend? I did realize that the motherboard is really damn expensive.
https://linustechtips.com/topic/1003386-first-pc-build/#findComment-12035801
MSI z390s arent bad from what ive heard.
RIP
https://linustechtips.com/topic/1003386-first-pc-build/#findComment-12035805
either a gigabyte or asrock imo
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/1003386-first-pc-build/#findComment-12035821
I recommend an 8th or 7th generation i7, as the per thread performance are within 5-8% of one another given that they are all Skylake refreshes, and both can be had for a lot cheaper, as can the motherboards.
And as for the motherboard, I recommend anything by Gigabyte or EVGA if you are insisting on 9th gen, however if you do take my advice and go with 7th/8th, I recommend ASUS, EVGA or Gigabyte.
i7-7700k | GTX 1080 Ti | 32GB 3100MHz | Prime Z270-AR
https://linustechtips.com/topic/1003386-first-pc-build/#findComment-12035822
Alright, I'll look into it. I'd hope to shave off about $200
https://linustechtips.com/topic/1003386-first-pc-build/#findComment-12035845
