Problem With The ATX12V
Solved by KarathKasun,
4 minutes ago, Hi P said:Is that safe? I don't want to damage it
It would be like connecting the EPS end into an ATX12V slot, 100% sure this works?
You could always trace it out with a multimeter.
It should work fine though, its keyed so that it will fit ATX 12v or EPS 12v. EPS 12v is backwards compatible to ATX 12v but not the other way around (power restriction AFAIK).
