So I broke the screen on my Huawei Mate SE, and being that I repair PC's and Laptops for family and friends, and that I've repaired phones in the past from about 3 generations prior, I figured that I could handle a simple screen replacement. I was wrong. The online tutorials were very poor, out of focus, and largely lacking directions. I was doing pretty good, however, until I had to remove the battery (You have to remove the entire phone assembly to reach the screen and frame). The battery was taped in, so as I was cutting the tape, I slipped and punctured the battery. It started shooting out sparks and erupting internally. Thankfully, I stayed calm and made sure it didn't catch anything on fire. I took it outside and placed it on my front porch to cool off in the freezing air. Once it cooled down, I took some photos of the damage and bagged it up to dispose of at a later date. So I guess I learned that most modern phones aren't really meant to be repaired. Looks like I'm buying a new phone (Same model, pretty cheap), but I did salvage the motherboard so I should be able to slot it in and still have my data. Photos below.
https://linustechtips.com/topic/1003158-my-phone-battery-exploded/
you only saved the motherboard because the motherboard's out when the firework started?
Desktop benching:
at least you are ok :) stay safe!
CPU: Ryzen 7 1700 @3.85Ghz, MotherBoard: Asus ROG Strix X370-F, RAM: G.SKILL TridentZ RGB Series 16GB 3000Mhz
GPU: GALAX GeForce® GTX 1080 Ti EXOC White, Case: NZXT S340 Elite Matte White, Storage: Samsung SSD 850 EVO 500GB, PSU: Corsair CX650M
