After being unsatisfied with my laptop I purchased in August of 2017 from Sager, I decided I'd like to build a desktop. I am putting in two Nvidia GTX 1070 Ti's (2 way SLI obviously) and have trouble trying to figure out what MOBO I should use to take full advantage of both GPU's.  This system I'm building is strictly for gaming and streaming.
Note* I know I only have a HDD selected as my storage. I plan on buying a 32 GB Intel Optane module to save a little money. I am open to suggestions to not do that.
Link to my PC Part Picker list:
https://pcpartpicker.com/user/dwreckdodious/saved/fcXCyc
Thanks in advance!
https://linustechtips.com/topic/1003145-building-my-first-pc/
Just be aware that SLI support is basically nonexistent these days, so unless you specifically know you can take advantage of it, get a 1080 ti.
Also, get an SSD.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1003145-building-my-first-pc/#findComment-12033585
The motherboard's disappointing for the budget
A single 2080 is better value for your money, it's better for that money to be spend on something else
Even if you get an Optane module, you should still buy a separate SSD because Optane is no magic, it cannot replace an SSD's dominant advantage in speed.
Even number of monitors for games at once will be odd. The crosshair will be on the edges of the screen
Desktop benching:
https://linustechtips.com/topic/1003145-building-my-first-pc/#findComment-12033597
I think you could have worded that a little better lol.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/1003145-building-my-first-pc/#findComment-12033630
Duly noted @fasauceome.
Also directed at @fasauceome, what motherboard would you suggest? I found an EVGA 1080 Ti for around $800. I also selected an SSD as opposed to Intel Optane.
UPDATED LIST:
https://linustechtips.com/topic/1003145-building-my-first-pc/#findComment-12033745
UPDATED LIST:
Buy a used by 1080 Ti. You should have no problem finding one still under warranty for $550 US. About the monitors, if you’re only gaming on one monitor, save $100 and buy a 60Hz panel as a second screen. No point in wasting that money.
https://linustechtips.com/topic/1003145-building-my-first-pc/#findComment-12033776
58 minutes ago, ItsDerekDude said:
@Cereal5,  I was planning to use that other monitor for gaming on my Xbox. I suppose you're right though!
Even so, Consoles are 30-60 FPS, right? And if a new console comes out in a couple years you can plug it into the 144Hz monitor. Unless you want two of the same, it’s your money
https://linustechtips.com/topic/1003145-building-my-first-pc/#findComment-12033925
UPDATED LIST:
I'm really pleased by my Z370 classified K, and the Aorus line from gigabyte has been great to work with as well.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1003145-building-my-first-pc/#findComment-12033937
