3 hours ago, Mrmaverick18 said:
So can i trust it along with its power supply
No. That case either shows a gray unit (usually a no name) or The Elite series which is rated one of the absolute worst PSU's on any of LTT's PSU Tier lists.
I'd skip this case entirely
https://linustechtips.com/topic/1002468-cooler-master-505-case/#findComment-12028790
Thank you for the advice, sadly i already bought it blindly a month ago and just found out its not on the cooler master site yesterday but i still didn't put a GPU there so far, using the internal GPU of i5 8400... So since i probably can't get a refund, should i buy and install a GPU 1060 or would it be too risky?
https://linustechtips.com/topic/1002468-cooler-master-505-case/#findComment-12029532
If you were to consider a GPU, I'd probably upgrade the power supply to something of better quality.
https://linustechtips.com/topic/1002468-cooler-master-505-case/#findComment-12032070
  • 6 months later...
Actually, I've got this CMP 505 case + 600W PSU with my MSI Z390 A-PROi3 8100, HIS RX 580 8GB OC, HyperX 3200MHz 8GB CL16 RGB, 2TB WD Blue... And it works beautifully so far without any problem! I can run absolutely any game on Max Settings + its LED fans are also so cool and the case is easy to set up. The only simply issue I had was the lowest fan in the front panel; Its cable is so short that I couldn't even connect it anywhere in the motherboard but since I'm kind of electrical engineering enthusiast; I've got 3 of my male-to-female wires and connected their 3 pins to the 3 slots in that short cable of the lowest fan; thus I've extended its range and easily connected it to my motherboard using this way; It just works, spins normally and lights up in RED light like any other fan and I've checked its speed from the BIOS; Actually no need to check that because it'd absolutely work correctly/normally but not all people are experienced with electronics so I've gotta clear things up. ^^
P.S don't know if it matters since it's my first time buying a computer case but it comes with everything you need to build things up in a small sack.
https://linustechtips.com/topic/1002468-cooler-master-505-case/#findComment-12679182
