Did you manually overclock?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1002250-gtx-970-clock-speed/#findComment-12026451
how hot is it running?
Desktop benching:
https://linustechtips.com/topic/1002250-gtx-970-clock-speed/#findComment-12026463
Just now, Dcit-223 said:
normal thermals 30c
what about under max load?
Desktop benching:
https://linustechtips.com/topic/1002250-gtx-970-clock-speed/#findComment-12026474
7 minutes ago, Dcit-223 said:
right now its at 43c with a game running
still low frequency? Give GPU-Z's newest version a shot.
Desktop benching:
https://linustechtips.com/topic/1002250-gtx-970-clock-speed/#findComment-12026501
50 minutes ago, Dcit-223 said:
It seems to be working fine now. Its evening hitting the boost clock. I restarted my pc and that seems to have cured it.
If it happens more,../again
Get a better PSU. (Likely generalization, but the GPU is getting starved for needed power, or the GPU has issues)
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/1002250-gtx-970-clock-speed/#findComment-12026705
