I have an i5 6600K overclocked to 4.6 GHz cooled by a Cooler Master Hyper 212x. The idle temps are around 40-60C (ambient being 25-30C) and also the load keeps bouncing around between 9% and 30%, it's never stable. What could be the issue?
Before I never had this issue, my idle temps were mostly 3-4C higher than the ambient so I really have no clue what is causing this. Also nothing seems suspicious in the task manager as well.
Should I upgrade my cooler to may be an AIO instead of air?
image.png.61c7ad8ca8b0c3e8db35339a2b190805.pngimage.png.7b01fafdd6bf701f5ae24a77ea462957.png
https://linustechtips.com/topic/1001950-cooler-upgrade/
Is this something that's been progressively getting worse over time, or was it a sudden change?
I find it unlikely that your TIM would have gone off with a chip as new as the 6600k, but it's still possible. How is the cooler itself, clean? Your fan(s), spinning?
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/1001950-cooler-upgrade/#findComment-12023668
It was all of sudden, it probably started a month ago...before that the temps were normal.
Also the cooler is pretty clean. I have checked everything that could bother the cooling although couldn't find anything suspicious except for the unsually varying idle load which is very unstable.
https://linustechtips.com/topic/1001950-cooler-upgrade/#findComment-12023737
There's some software using multiple cores in background. Temps are still normal. You can run stress test to see if there's even need to do something with cooler.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1001950-cooler-upgrade/#findComment-12024487
I did stress test it with CPUZ and Cinebench, during which i get temps upto 82C max. Also my pc starts lagging during the stress test. Am begining to think it also may be a CPU issue.
https://linustechtips.com/topic/1001950-cooler-upgrade/#findComment-12031151
Its not temps issue. Temps are still within reason. Not that good, but nothing to really mean you'd need new cooler.
As for this lagging (=network term so we use stuttering), its more likely RAM or drive related than CPU being problem. If it was CPU, you would see it underclocking/throttling.
https://linustechtips.com/topic/1001950-cooler-upgrade/#findComment-12032121
