Hey everyone, I'm building my first PC and had a quick question regarding the USB headers available on the Z390-A motherboard. The one that I'm looking at particularly is Asus PRIME Z390-A for my build with a i9 9900k processor. I'm getting some conflicting results on google so I figured I should ask here. Hopefully you can help, thanks!
https://linustechtips.com/topic/1001746-z390-a-usb-headers/
Are you asking for amount of usb ports?
Z390 supports 3.2 gen1 usb ( 6 ports ) onto of everything z370 gives you
I may be wrong.
https://linustechtips.com/topic/1001746-z390-a-usb-headers/#findComment-12021598
Google might give you conflicting answers but ASUS won't.  Do yourself a favor and download the manual for the motherboard you're interested in and give it a read.
https://www.asus.com/us/Motherboards/PRIME-Z390-A/
"And I'll be damned if I let myself trip from a lesser man's ledge"
https://linustechtips.com/topic/1001746-z390-a-usb-headers/#findComment-12021619
I checked the manual, thanks for that. For future readers, the image shown above says 2 x front USB 3.1 Gen1 headers but in reality that is combining the Type C and Type A together. The promotional material is not correct... There is only 1 USB 3.1 Gen1 TypeA and another USB 3.1 Gen1 TypeC connector for your cases' chassis. Furthermore, both the manual and motherboarddb.com shows it only has 1 USB 3.0 header.
https://motherboarddb.com/motherboards/1369/Prime Z390-A/
https://linustechtips.com/topic/1001746-z390-a-usb-headers/#findComment-12021815
It is a little misleading.  What they are trying to say " 1 x USB 3.1 Gen 1 header supports additional 2 USB 3.1 Gen 1 ports"
Reading it again I have no idea why ASUS did their promo like that.  Luckily the manual is correct.  Another point for always read the manual.
https://linustechtips.com/topic/1001746-z390-a-usb-headers/#findComment-12021851
It looks like the "advertising" is showing how many PORTS are available, NOT how many headers.
If that is the situation, they are correct.
A single USB 3 Header can supply two USB 3.0 ports.
The USB-C Header only supply one USB-C port.
(Two USB 2.0 Headers, so four USB 2.0 ports)
EDIT:
This is also consistent with the rear I/O labeling...
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1001746-z390-a-usb-headers/#findComment-12021965
