I Need pseudo code help
shawn803
calculate the tip amount and total cost on a given bill. The program will receive the following input from the user: Bill Amount (float) and Tip Percent (integer). The program will return the following to the user: Tip Amount (float) and Total Cost (float). In your design you will need to do the
following:
   1.        Receive the input from the user
   2.        Calculate the tip amount
   3.        Calculate total cost
   4.        Display the results
Example calculation:
Bill Amount: $56.23
Tip Percent: 18%
Tip Amount: 56.23 * (18/100) = 10.12
Total Cost: 56.23 + 10.12 = 66.35
Design a program with pseudocode that solves this problem.
I just learning and im so lost ,i dont know what to do,and i cannot get no help from no one
Well, you need 2 variables and a constant, the tip, then just write it out in plain English e.g,
var total as real
const tip as real = 18/100
var bill as real
input bill(56.23)
total = bill+ bill*tip
Output total
Always remember to indent and use sensible variable names.
@shawn803
var total as real
var bill as real
input bill(56.23)
Output total
@shawn803
I guess it depends on the language but the tip shouldn't/can't be constant if it is given by the user.
1474412270.2748842
I wrote this in Python quickly
Bill = input ("Bill here: ")
Tip = float(Bill)*0.18
print "The Tip is: "+str(Tip)
print "The total bill is: " +str(Bill+Tip)
input ("\n\nPress Enter to Exit")
Setup: i5 4670k @ 4.2 Ghz, Corsair H100i Cooler, Corsair Vengeance Pro 16GB Ram @ 1600 Mhz, MSI Z87-GD65 Motherboard, Corsair GS700 2013 edition PSU, MSI GTX 770 Lightning, Samsung EVO 120 SSD + 2TB&1TB Seagate Barracudas, BenQ XL2411T Monitor, Sennheiser HD 598 Headphones + AntLion ModMic 4.0
Thanks Chris this class is kicking my butt,and my teacher don't seem  like they have time to explain it to me
Tell your teacher that pseudo code is pointless. Why write pseudo code when writing the real code is just as simple and easier for others to understand?
Because when you're designing algorithms later on, it helps to represent it in pseudocode for those looking at your papers that may not understand certain languages.
Pseudo code is far from pointless. It may not look so on very simple problems, but when approaching a problem that is going to turn into a couple of hundred or thousand lines of code it really makes the job easier.
