Corsair Raptop HS40 USB problem.
refinedskillz
I have a pair of Corsair Raptor HS40 headphones, they connect via USB, but when plugged in, disconnect after a while, the sound volume is then reset too really loud so it makes the headphones pretty much unusable. Anyone would know a fix?
Ryzen 5 1600 - GTX 980 Ti - Broke.
Is the headset brand new? or it has been 2-3 years of usage?
and are there drivers for it? update it if there are any newer version of it...
Usually, if the USB loves to randomly connect and disconnect anytime, its a sign of USB failure and the headset is deteriorating, well in my experience with USB stuff.
Cpu R5 1600 @3.7ghz - MB Gigabyte AB350 Gaming 3 - RAM Corsair Vengeance LPX 8GBx2 @3000mhz - GPU Palit GTX 1070ti Dual - Storage Kingston FuryX 120GB SSD, WD 500GB Green HDD, Seagate 1TB HDD - PSU Seasonic X650 - Case Sharkoon S25-W - Display Zowie XL2411 - Peripherals Filco Ninja Browns, Zowie FK2 & Qck Hyperbeast Ed.
They are brand spanking new.
Have you tried in a different pc? if the problem still exist, you got the faulty one, just RMA them or refund if you can and get something better.
