Help with finding a monitor
Troy
Hi, I am looking for two monitor for my setup.
Also I need one that is for gaming with these specs and I am not sure whether to go with a TN panel or an IPS panel. The second one is just going to be in portrait mode next to the other monitor, so it doesn't have to have the same specs and can be cheaper. I would like that monitor to be 24". My budget is $600.
these are the specs I am looking for
  • 24 - 27"
  • 1440p
  • be able to go on a monitor mount
here are my specs                http://pcpartpicker.com/p/DFQzXL
Thank you
