Need help - Power to Motherboard but PC won’t start - SOLVED
Solved by MattBarnettNZ,
Final update
Have just put everything back together and installed my new case fans and CPU fan. It all works fine now, turns out I’m a bit of an idiot and overlooked that I had also recently replaced some other cabling (SATA cables) and they seemed to be faulty which is what was causing the issue when trying to boot.
All has been resolved and PC is working just fine. Have a good weekend everyone
