Need help with old laptop drive cloning
Solved by SSD Sean,
32 minutes ago, star_pilot475 said:@SSD Sean is there any way to transfer data through Cat5 data cable?
That’s easy peasy. Lol. Just connect both systems to the same switch or router. Set up a network share on your main PC. (Don’t forget to give permissions to “everyone.”)
Connect to the network share from your laptop and drag n drop or use free file sync and mirror the folders over that you want the data from.
Need more details? Let me know. I can write specifics when I’m home. It’s really easy.
