i dont think so
Specs
https://linustechtips.com/topic/99909-will-dyes-gunk-up-my-loop/#findComment-1336368
Don't use anti freeze.
But if you use good quality products and make sure they aren't going to react to each other then you won't have an issue.
9 times out of 10 it's tubing that's the issue, not coolant
im using primochill advanced lrt
if you are reading this you are wasting valuable time and should maybe rethink your life choices.
https://linustechtips.com/topic/99909-will-dyes-gunk-up-my-loop/#findComment-1336374
ive seen many coolants that would separate from the dye and gunk up the heatsinks and rads after  time
http://www.techpowerup.com/forums/threads/water-cooling-coolant-choices.86819/#post-1238967
http://www.techpowerup.com/forums/threads/primochill-dye-bomb-fail.178530/
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/99909-will-dyes-gunk-up-my-loop/#findComment-1336407
That is from 5 years ago....
Dyes have moved on since then.
Dont mix dye with glycol,it will clump and separate.
SR-2-2x X5650 Xeons-3x 670 FTW-1x 120Gb Force GT-1x 240Gb Force GT-1tb WD Green-12Gb Dom GT 1866-Platimax 1500w-2x HK3-2xD5-24v controller-3x RX 480's-3x NiBlk HK GPU blocks-Koolance tops-BP res-15x SP120's-Little Devil V8.
https://linustechtips.com/topic/99909-will-dyes-gunk-up-my-loop/#findComment-1336421
im still on the fence about all this. im using a clear dye that turns blue under uv. will it still gunk?
https://linustechtips.com/topic/99909-will-dyes-gunk-up-my-loop/#findComment-1336451
If you get any gunk in your loop it is most likely the fault of plasticizer leaching from the tubing, that is then dyed by the dye in the loop.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/99909-will-dyes-gunk-up-my-loop/#findComment-1338469
Yeah they can which is why I am going for clear tubing and clear fluid from now on.
https://www.dropbox.com/sc/3x98tf0lxtx7l8q/On0gezptIS
That was from Feser UV Acid Green fluid that was in a loop for 6 months in my brother in laws pc.
It shut the pump down and clogged everything which caused the pc to shut off whilst at a lan, luckily it didn't take anything out and just needed a drain, filter and loop rebuild which took 2 days.
Core I7 3930K 4.6ghz, Rampage IV Extreme, 16GB Corsair Vengance 1600mhz, GTX 780Ti SLI, Corsair Force 3 240Gb SSD, Asus Xonar DX, Killer Xeno Pro, Phobya Easy Bench V3, Phobya Extreme Nova 1080
https://linustechtips.com/topic/99909-will-dyes-gunk-up-my-loop/#findComment-1342866
