hi guys need help with new ram for my motherboard its the asus rog strix b350-f gaming.
when i was looking at the mobo manufacture website qvl i saw some ram that wasn't that expensive
Corsair CMK8GX4M2B3000C15 Vengeance LPX 8 GB (2 x 4 GB) DDR4 3000 MHz C15 XMP 2.0 High Performance Desktop Memory Kit, Black
https://www.amazon.co.uk/gp/product/B0123ZBPDA/ref=ox_sc_saved_title_1?smid=A3P5ROKL5A1OLE&th=1
(17th down the table)image.thumb.png.8b230f525650e6440f948b2aa38b94c7.pngthis ram in brackets has version 3.21 and i know this means it will be (Micron B-Die) memory chip. does this matter in terms of compatibility with the mobo do i need a specific memory chip for it to work. and does anyone have other alternatives to this ram that will perform better than it. a link to the product would be great>
https://linustechtips.com/topic/998946-ram-help/
Corsair Vengeance LPX is a pretty good RAM! If you can get it for cheap, definitely go for it! Especially because it has a CAS latency of 15.
CPU: AMD Ryzen 5 5600X | MOBO: MSI B450 Tomahawk GPU: AMD Radeon RX 6800XT | RAM: GSkill Trident Z DDR4 3600Mhz | PSU: ADATA Core Reactor 850W 80+ Gold | CASE: Fractal Design Meshify C MONITOR: LG 32UL500-W 4K 60Hz, Gigabyte M27Q 1440p 165Hz
https://linustechtips.com/topic/998946-ram-help/#findComment-11998458
