4 minutes ago, Solidsoul88 said:
Will a Intel Core i7 8700K fit in an ASUS Prime B250M-A ?
no, you need a 300 series motherboard
Z370 if you wanna be able to overclock
or B360 if you don't care about overclocking, but then it's cheaper to use a non-K CPU for that
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/998932-need-help-with-cpu-mb/#findComment-11998366
53 minutes ago, Solidsoul88 said:
So if i get ASUS ROG Strix B360-G Gaming Motherboard and replace my ASUS Prime B250M-A will i need to change anything other than my CPU?
you don't need to change anything else, but make sure you have a good Power Supply because i don't know what system you have been running
https://linustechtips.com/topic/998932-need-help-with-cpu-mb/#findComment-11998624
