So i live in the north, and every night i turn off the heat in my home to save some money. Which in turn causes the temperature to drop to around 10-20°f. Ive been wondering is this damaging my graphics card because ive been geting some terrible halo affects when i fist turn the pc on. After a few restarts it goes away but by then the card is around 20-30°c.
https://linustechtips.com/topic/998853-cold-temps/
no, if LN2 is fine then why would this do any damage? the only thing might be if there is condensation from high humidity i guess? but the cold itself isnt doing any harm directly
Builds:
https://linustechtips.com/topic/998853-cold-temps/#findComment-11997905
It's possible the halo is due to the monitor getting cold and not the PC.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/998853-cold-temps/#findComment-11997913
