Hello everyone,
I'm looking forward to make use of the Black Friday sales so I will be upgrading my PC heavily. Below you can find my current specs, I plan on upgrading my GPU, CPU, Motherboard and Memory. I could really use some advice on which ones I should be getting. I have already decided that I want a MSI RTX 2070 Gaming Z as my GPU upgrade. Haven't decided on the rest yet, my budget is mid range I would say (Looking for the best value for money). For the CPU I was looking at a AMD Ryzen 5 2600 3.4GHz (since I would have to upgrade because it wouldn't be compatible with a new motherboard)
Current planned upgrades:
Graphic Card: MSI RTX 2070 GAMING Z (609 euro)
CPU: AMD Ryzen 5 2600 3.4GHz (129 euro)
Motherboards: (Something that fits into my case and is compatible with the rest)
Memory: (Something that fits into my case and is compatible with the rest, most likely 16GB even though I think that's already more then I need)
Specs:
Operating system: Windows 10 Home 64-bit
Memory: Crucial Ballistix Sport DDR3 8GB (2x4GB) 2400MHz
SSD: Crucial 240 GB SSD
CPU: Intel Core i7 4790K @ 4.00GHz
Storage: Western Digital 1 TB HDD
Graphic Card: MSI NVIDIA GTX 970 GAMING 4G
Motherboard: MSI Z97 GAMING 3
Power supply: Corsair VS650
Case: Corsair Spec 01 Red
https://linustechtips.com/topic/998780-desperate-for-upgrade-help/
