Hi! I need help with a PC upgrade. This is my current PC, is a prebuilt PC.
HP Pavilion Desktop - 560-p058ns
Motherboard
My current issue is that the CPU (i3 6100) is bottlenecking my NVIDIA 1060 3G.
What I wanna do?
I want to upgrade the CPU and what I THINK is a good replacement is the RYZEN5 2600...
BUT if I buy the RYZEN I would need to buy a B450 motherboard and also a new case and power supply (this one came with only 300W. I would keep the same 8gb RAM and GPU.
I'm a noob in PC matters... always been a laptop guy but this past year I fell in love with PC gaming.
Do you guys agree with my choices?
I don't wanna pay too much for the upgrade but also want something that kinda is future proof (get 1070 in a year or something).
Thanks!
https://linustechtips.com/topic/998406-help-with-pc-upgrade/
yes, Ryzen is better for your money.
next year? If it's at the second half of next year then you're looking at Navi, AMD's next gen card.
Desktop benching:
https://linustechtips.com/topic/998406-help-with-pc-upgrade/#findComment-11994766
If you do this you'll just be building a whole new PC, this is what you want isn't it?
The wording of this thread makes it sound like you want to upgrade your current pre-built not build a whole new system.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/998406-help-with-pc-upgrade/#findComment-11994779
Check out eBay for a used i5, it's gonna be a lot more convenient than Ryzen upgrade. Also, you will probably need some new thermal paste to reapply to the cooler.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/998406-help-with-pc-upgrade/#findComment-11994797
Well, my current motherboard doesn't work with ryzen so that would mean a new one and my current case is too small I think...
That´s why I'm asking if it makes sense what I wanna do. The cheaper the option the better.
https://linustechtips.com/topic/998406-help-with-pc-upgrade/#findComment-11994818
10 minutes ago, Firewrath9 said:
you might be able to find a used i5-6500/7500 or something like that. It would be much cheaper.
Cant! Would need a new motherboard.and by that point is gonna be the same. The ryzen has better performance right?
Current motherboard works with this:
Processor
TDP
Integrated Graphics
Intel Core i7-6700K (Skylake) 4.0 GHz Quad Core (only with Ariia+)
91 W
Intel HD Graphics (GT2)
Intel Core i7-6700 (Skylake) 3.4 GHz Quad Core
65 W
Intel Core i5-6400 (Skylake) 2.7 GHz Quad Core
65 W
Intel Core i3-6100 (Skylake) 3.7 GHz Dual Core (only with Hal2)
51 W
Intel HD Graphics 530
https://linustechtips.com/topic/998406-help-with-pc-upgrade/#findComment-11994825
Processor
TDP
Integrated Graphics
91 W
65 W
65 W
51 W
You shouldn't need a new motherboard for these CPUs. Is there a compatibility list explicitly saying LGA 1151 CPUs aren't compatible like they usually are? The i7 6700 would have better gaming performance than Ryzen as well (of course not by much at all)
Primary PC:
PSU tier list
https://linustechtips.com/topic/998406-help-with-pc-upgrade/#findComment-11994831
Processor
TDP
Integrated Graphics
91 W
65 W
65 W
51 W
if its compat with those, its compat with the i5-6500.
whatever, get a i5-6700 or i5-6400.
https://linustechtips.com/topic/998406-help-with-pc-upgrade/#findComment-11994832
i5 6700 is 263 euros here!
The 2600 ryzen is 170 euros right now.
You should never get a 3 generations old i7 for new
Primary PC:
PSU tier list
https://linustechtips.com/topic/998406-help-with-pc-upgrade/#findComment-11994855
