i just upgraded my old pc with a new cpu, mother board and ram ( AMD Ryzen 7 2700 Prosessor, MSI X470 GAMING PRO CARBON, Socket-AM4, Corsair Vengeance RGB DDR4 3000MHz 32GB )
the change was seemless in on the start with no noticeable problems but now both my screens freeze then goes black for 3-10 seconds before coming back and this happands every 10 min or so, sometimes even 1 minute.
but the problem doesnt stop there, everytime it goes black it crashes my games and videos i have in the backgrond making it impossible to play with friends or watch anything.
anyone that have had the same problem or know a fix to this?
edit:
specs:
Windows 10 Pro 64-bit
ASUS GeForce GTX 1080 Ti Turbo
Corsair RM850, 850W PSU
https://linustechtips.com/topic/998321-having-problems-after-upgrade/
what are the rest of your specs?
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
Did you reinstall Windows when you upgraded your hardware? what hardware you had before if you kept your old windows install?
Personal Desktop":
Luna, the temporary Desktop:
my old hardware was the same except for the motherboard, ram and cpu.
old specs:
HyperX Fury DDR3 1600MHz 16GB
Intel Core i7-6700K Skylake Prosessor
and the motherboard im not sure, i dont have it with me, all i remember is that it was asus.
Have you pulled your GPU and reseated it yet?  And it may help to wipe down the pins on your GPU with some rubbing alcohol.  Also, did you check the power connectors on everything?  PSU and component sides.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
2 hours ago, BlueCosmonaut said:
when i pull out the gpu and try to get picture from the motherboard i get nothing.
No, no.  You can't leave out the GPU.  The 2700X doesn't have a GPU on the die like almost all Intel CPUs.  The reason your board has any video out ports is for an instance a user installs a 2200G or 2400G or another AMD CPU with built in GPU.
I wanted to make certain you GPU was seated well and that the pins were clean and not suffering from any interference there.  That and the power cables were all firmly installed too.
ah sorry i forgot there was no onboard gpu, but to awnser that question better:
i had a spare gtx 970 to test on the rig and when i plugged that in the same problem happand.
i even tried plugging in the gpu to the next pci just to see if the first one was bad but same problem.
Are you using a modular power supply?
Also, have you checked your monitor?  Its power cable and connection to its power source?
also today i tried diffrent things with the gpu and it seems like it is the gpu that is triggering mosy of these problems, but i cant put my finger on where the problem accures cause if i put the 1080ti in my old rig it works fine, so i think the problem is with the motherboard not giving the power the gpu needs or something.
but im really not sure how i can check this or how to fix this.
yes i have a modular power supply, and both my monitors cables are fine, im very positive that the problem comes from the computer cause both screens freeze and goes black at the same time and comes back aswell.
Are you using the correct cables for the GPU power and is it seated well?  I'm just hoping it isn't your mobo so you won't have to deal with tearing it all down.  That would be a pain in the a**.
yeah im positive, i usees the same cables on my old rig and it worked fine, gonna have a lan tomorrow so i will probably have to take it apart with my friends and look at it.
Update:
i think i have an awnser to my problem that i found by accident, i pluged out my hdmi screen from the gpu and left only my displayport screen inn and now i can play games and watch videos without that problem i talked about earlier, but this is still annying cause now i cant use my second screen so my question is: have anyone encountred this problem where you can only use one screen?
Update: the screen was fine for 1 hour and when i tried to watch youtube insted of netflix it did the freeze black and back thingy again ;-(
Best of luck getting it sorted.
