What CPU's are going to work on this motherboard?
Guest
I've got an old Acer M1610 mobo with 775 socket support, sis 672 chipset, currently its running a Pentium D cpu, I would like to upgrade to the latest CPU possible.
I've seen some modified Xeons for 775 socket from aliexpress, would they work?
Also, from here --> http://www.ascendtech.us/foxconn-lga775-672m01-1-1-8eksh-ddr2-mb_i_mb4672m0118eksh.aspx it says it supports CPU's only up to 800Mhz FSB and only core 2 duo's, is that true? What would happen if I put a 1200Mhz FSB CPU on it? Would it work anyway? Or maybe a Core 2 quad.
According to Wikipedia the SIS 672 chipset only supports up to Core2 Duo. But any Core2 Duo would be a big upgrade from the Pentium D
Intel Core i9-10900X, Asus TUF X299 Mark 1, 64GB DDR4 3200MHz, Asus GTX 1080 Strix, 2TB 970 EVO Plus, 2TB SN570, 8TB HDD, DC Assassin III, Meshify 2
Old PC: Intel Xeon X5670 6c/12t @ 4.40GHz, Asus P6X58D-E, 24GB DDR3 1600MHz, Asus GTX 1080 Strix, 500GB, 250GB & 120GB SSD, 2x 4TB & 2x 2TB HDD, Fractal Define R5
PC 2: Intel Xeon E5-2690 8c/16t @ 3.3-3.8GHz, ThinkStation S30 (C602/X79), 64GB (4x 16GB) DDR3 1600MHz, Asus GeForce GTX 960 Turbo OC, 1TB Crucial MX500
PC 3: Intel Core i7-3770 4c/8t @ 4.22-4.43GHz, Asus P8Z77-V LK, 16GB DDR3 1648MHz, Asus RX 470 Strix, 1TB & 250GB Crucial MX500 and 3x 500GB HDD
Laptop: ThinkPad T440p, Intel Core i7-4800MQ 4c/8t @ 2.7-3.7GHz, 16GB DDR3 1600MHz, GeForce GT 730M (GPU: 1006MHz MEM: 1151MHz), 2TB SSD, 14" 1080p IPS, 100Wh battery
Laptop 2: ThinkPad T450, Intel Core i7-5600U 2c/4t @ 2.6-3.2GHz, 16GB DDR3 1600MHz, Intel HD 5500, 250GB SSD, 14" 900p TN, 24Wh + 72Wh batteries
Phone: Huawei Honor 9 64GB + 256GB card Watch: Motorola Moto 360 1st Gen.
General X58 Xeon/i7 discussion
Some other PC's:
Some of the specs of these systems might not be up to date
PC 4: Intel Xeon X5675 6c/12t @ 3.07-3.47GHz, HP 0B4Ch (X58), 12GB DDR3 1333MHz, Asus GeForce GTX 660 DC2, 240GB & 120GB SSD, 1TB HDD
PC 5: Intel Xeon W3550 @ 3.07GHz, HP (X58), 8GB DDR3, NVIDIA GeForce GT 640 (GPU: 1050MHz MEM: 1250MHz), 120GB SSD, 2TB, 1TB and 500GB HDD
PC 6: Intel Core2 Quad Q9550 @ 3.8GHz, Asus P5KC, 8GB DDR2, NVIDIA GeForce GTX 470, 120GB SSD and 500GB HDD
HTPC: Intel Core2 Quad Q6600 @ 3.0GHz, HP DC7900SFF, 8GB DDR2 800MHz, Asus Radeon HD 6570, 240GB SSD and 3TB HDD
WinXP PC: Intel Core2 Duo E6300 @ 2.33GHz, Asus P5B, 2GB DDR2 667MHz, NVIDIA GeForce 8500 GT, 32GB SSD and 80GB HDD
RetroPC: Intel Pentium 4 HT @ 3.0GHz, Gigabyte GA-8SGXLFS, 2gb DDR1, ATi Radeon 9800 Pro, 2x 40gb HDD
My first PC: Intel Celeron 333MHz, Diamond Micronics C400, 384mb RAM, Diamond Viper V550 (NVIDIA Riva TNT), 6gb and 8gb HDD
Server: 2x Intel Xeon E5420, Dell PowerEdge 2950, 32gb DDR2, ATI ES1000, 4x 146gb SAS
Dual Opteron PC: 2x 6-core AMD Opteron 2419EE, HP XW9400, 32GB DDR2, ATI Radeon 3650, 500gb HDD
Core2 Duo PC: Intel Core2 Duo E8400, HP DC7800, 4gb DDR2, NVIDIA Quadro FX1700, 1tb and 80gb HDD
Athlon XP PC: AMD Athlon XP 2400+, MSI something, 1,5gb DDR1, ATI Radeon 9200, 40gb HDD
Thinkpad: Intel Core2 Duo T7200, Lenovo Thinkpad T60, 4gb DDR2, ATI Mobility Radeon X1400, 1tb HDD
Pentium 3 PC: Intel Pentium 3 866MHz, Asus CUSL2-C, 512mb RAM, 3DFX VooDoo 3 2000 AGP
Laptop: Dell Latitude E6430, Intel Core i5-3210M, 6gb DDR3 1600MHz , Intel HD 4000, 250gb Samsung SSD 860 EVO, 1TB WD Blue HDD
Laptop: Latitude 3380, Intel Pentium Gold 4415U 2c/4t @ 2.3GHz, 8GB DDR4, Intel HD 610, 120GB SSD, 13.3" 768p TN, 56Wh battery
5 hours ago, firelighter487 said:
Those scores are a bit weird. That Core2 Duo has 33% better single-core speed but 12% slower multi-core even though both are dual core CPU's? I know it has hyperthreading but it shouldn't make such a big difference. Core2 Duo E8400 has 48% better single-core speed and 0% difference on multi-core, but I'm sure it would easily destroy that Pentium D on everything.
This is more like what I'd expect the difference to look like: https://www.cpubenchmark.net/compare/Intel-Pentium-Extreme-Edition-965-vs-Intel-Core2-Duo-E8200-vs-Intel-Core2-Duo-E8600/1132vs950vs957
Some other PC's:
