Hello,
So I just got my case in and was looking at the fans. All the fans connect to 1 cable. The end of the cable is a molex though. Do I need to get an adapter for the molex to a type of fan header so it will work in my mobo? My motherboard is the Asrock b450 pro. Here is a pic of the cable.
20181121_172225.jpg?width=369&height=656
https://linustechtips.com/topic/997954-help-with-fan-cables/
Those fans plug directly into a molex connector from your PSU.
There looks to be an adapter that takes the fan connectors and converts that to Molex, see if those come apart at all.
-Moved to Air Cooling-
https://linustechtips.com/topic/997954-help-with-fan-cables/#findComment-11991271
nah just plug it to a molex cable from the power supply. If you want fan speed control you shouldnt use an adapter like this in the first place.
Desktop benching:
https://linustechtips.com/topic/997954-help-with-fan-cables/#findComment-11991273
If I unplug them from the molex and put them into the mobo will it still work? I hope I can because they are RGB fans and I dont see how I would control it unless it is in the mobo. The case I got was the Masterbox lite 5 RGB btw.
https://linustechtips.com/topic/997954-help-with-fan-cables/#findComment-11991275
It should work
https://linustechtips.com/topic/997954-help-with-fan-cables/#findComment-11991282
