Will these components works good together?
Solved by lmeneses,
I mean, yes the build will work together, obviously you know that the mobo will not be able to oc that well. Also, maybe try and fit a 120gb ssd into the build, but other than that it is fine, and upgrading from a 1600x to a 2600 is pointless. And maybe you shouldn't have spent so much on a gpu rather than a mobo
Featured Topics
kasdashd ·
Edgar R. Zakarian ·
Posted in CPUs, Motherboards, and Memory7 -
3
3
