So im planning my first build, and would like some help choosing the hardware with the best value
My build so far is under the 5 questions
1. Budget & Location
Preferrably using the www.komplett.no website (simple to use a norwegian website considering shipping, support, prica match and such)
Currency: Norwegian Krone (NOK)
1USD=8,29NOK
Budget: 1500USD (12500NOK) but can be pushed up to 1800USD (1500NOK)
2. Aim
This is a build for Gaming
But i will also use it for university so decent storage is needed
3. Monitors
24-27'' 2560x1440 60hz+
I'm only going to use it with one gaming monitor, but i'd like to be able to occasionally plug in a second one with potentially better resolution for movies and pictures
4. Peripherals
I will need
The build itself (The smaller tower the better, but a mid tower is fine)
Windows Home
1x Monitor
5. Why are you upgrading?
I finally have the money, and want something more stable and better cooled than a laptop
I don't know if it's problematic to help me on a norwegian website, but google translate can hopefully help you if you need more information on anything. There are some sales on the website that might change which hardware is best, but i don't know how to fix that issue for you guys.
Anyways here is a pre-made build on the website with parts on sale:
AMD AM4 Ryzen 5 2600X 2149NOK 251,24USD
ASUS ROG STRIX X470-F GAMING 1490NOK (31% off 2149NOK) 174,20USD (31% off 251,24USD)
HyperX Fury DDR4 2666MHz 16GB 1585NOK 185.33USD
Samsung PM981 SSD 512GB (No price, not selled seperately)
Corsair Carbide SPEC-05 Midi Tower 599NOK 70,04USD
Corsair TX550M 550W PSU 599NOK (26% off 809NOK) 70,04USD (26% off 94,60USD)
ASUS GeForce GTX 1070 DUAL OC 3990NOK (23% off 5190NOK) 466,55USD (23% off 606,86USD)
All pre-made builds also include:
CPU-fan
Thermal paste applied on CPU
All necessary cables
Manuals
Total: 11990NOK (22% off 15290NOK)
Total: 1402 USD (22% off 1787,88 USD)
I have also been looking at a monitor and wonder if its decent considering price/performance and to my build:
https://www.komplett.no/product/1090437/gaming/gamingskjermer/samsung-27-led-c27jg50?offerId=KOMPLETT-310-1090437
Samsung 27" LED C27JG50
2560x1440 VA, 144hz, 4ms, 3000:1, 1800R, 2xHDMI/DP
2849NOK (25% off 3795NOK)
333,39USD (25% off 444,09USD)
Windows Home is sold at the same website for 1299NOK 152USD
Dont know if its cheaper any other place
https://linustechtips.com/topic/997683-my-first-build/
1USD=8,29NOK
2. Aim
3. Monitors
4. Peripherals
I will need
Windows Home
1x Monitor
CPU-fan
Manuals
You can get a key for Windows off of EBay for £1.50.
Use that to get used GTX 1080. If it's an EVGA one, warranty is transferable so no risk.
2600X is a good choice.
What's the cooler you gonna use?
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
https://linustechtips.com/topic/997683-my-first-build/#findComment-11989039
Thanks for the windows tip.
so the only main problem i have with this is since its a prebuild i dont know what cpu cooler is in there, and i cant remove any single peace of hardware
If i were to upgrade to a GTX 1080 i would have two choices:
1: Buy both the GTX 1070 and the GTX 1080 and sell the GTX 1070 after
2: Buy the build not prebuild for 10412NOK 1218,75USD WITHOUT a CPU cooler, thermal paste, and the Samsung PM981 SSD 512GB
https://linustechtips.com/topic/997683-my-first-build/#findComment-11989059
I'd buy it all separately. It will be cheaper. You can get an used air cooler like Noctua DH15, SSD will be your choice (and it's cheap on Amazon now Black Friday).
Use Black Friday to your advantage dude, and used market. GTX 1080 will be cheap now.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/997683-my-first-build/#findComment-11989075
