Planning a build for someone I know. Yes I chose a 2080. As the 1080ti is gone.
any tweaks I should do?
https://linustechtips.com/topic/997111-planing-a-build/
3 minutes ago, ShoByte said:
Get a Corsair RM650x PSU, throw in a HDD, get an EVGA Z370 FTW motherboard, and swap out the AIO liquid cooler for a Dark Rock Pro 4, Dark Rock 4, or NH-D15.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/997111-planing-a-build/#findComment-11984137
what is your budget and location?  what is the build going to be used for?  if your just looking for advice on this current list then swap out the psu for like a corsair rm series or even a evga psu beleve the g2 are really good and maybe add a mechanical drive for mass storage.
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
https://linustechtips.com/topic/997111-planing-a-build/#findComment-11984151
The rosewill is a tier 2 psu as well, what's better about the corsair?
https://linustechtips.com/topic/997111-planing-a-build/#findComment-11984155
EVGA - SuperNOVA G2 650 W is the same price and a better psu. Granted it is only 650W, but that is more than enough capacity for the build.
SeaSonic FOCUS Plus 650 Gold and Corsair RM650x (2018) would be better choices than the Capstone, IMO.
Otherwise, it's a good build.
https://linustechtips.com/topic/997111-planing-a-build/#findComment-11984174
Never noticed the seasonic in tier 2. I've always had problems with large coolers and tall ram.
Revised
Cooler is under other, i had to manually put it in.
https://linustechtips.com/topic/997111-planing-a-build/#findComment-11984219
The NH-D15 and Trident Z memory are not a great combination. The outer fan of the NH-D15 overhangs the outer memory slots. As a result, a memory upgrade might be troublesome. Consider the Dark Rock Pro 4 instead. While it overhangs memory, clearance is sufficient for Trident Z modules. Another option would be the NH-D15S.
Not sure why you couldn't find the Noctua - NH-D15 82.5 CFM CPU Cooler entry.
https://linustechtips.com/topic/997111-planing-a-build/#findComment-11984232
Doesn't show, neither does the Dark Rock Pro 4 =/
It was the compatibility filter. It's saying the case is the problem.
https://linustechtips.com/topic/997111-planing-a-build/#findComment-11984235
9 minutes ago, brob said:
Doesn't have the LED fans, but does have excellent airflow Fractal Design - Meshify C TG.
I'll add in a HDD if it's needed. She doesn't really care about LED/RGB so that's fine.
https://linustechtips.com/topic/997111-planing-a-build/#findComment-11984287
8 hours ago, ShoByte said:
You can get Windows 10 for $15 on Kinguin
https://linustechtips.com/topic/997111-planing-a-build/#findComment-11985358
