so i have the Gigabyte 78LMT-USB3 board, it only has 2 fan headers, cpu, and sys fan. i would like to get the Cooler Master N200 it comes with two fans. so, should i get a fan splitter cable. Or get a fan hub with like 10 fan connections, or is there any way i can power the fan with a power cable adapter (i don't care if the fan is at 100% all the time) like i see i have a small 4 wire cable, it looks like i could plug into the fan header on mobo so the spacing would be right. So if i had a adapter could the fan plug into that?
EDIT: that was confusing, i am NOT plunging a power cable into the fan header, i was using that example to show that the wire spacing is the right size
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/99687-fan-options/
