Hello! How can i improve stream quality on OBS my internet speed is 60 down and 20 up my bit rate on OBS set to 13000 but quality is still extremely bad. And when i'm trying to use my cpu (8700K) stream quality is beautiful but the actual stream have like freezes. And yes i have set CBR!
Pls HELP!
My rig:
i7 8700K (not overclocked yet)
MSI GAMING X PLUS 1060 6GB (OC)
Corsair Vengeance 3200mhz 16gb
Intel Optane 32 GB
https://linustechtips.com/topic/996488-bad-obs-stream-quality/
What service are you streaming to?
PC Specs:
CPU: AMD 1700x Cooler: Corsair H100i V2 Motherboard: Asus Crosshair VI Hero RAM: 4 * 8GB G.Skill RGB DDR4 Graphics: EVGA GTX 1080 Ti SC2 Storage: Samsung 960 EVO 500GB Case: Fractal Design Meshify C PSU: EVGA 750w G3 Monitors: Dell SG2716DG +  2x Dell U2515H
Freenas specs:
CPU: Intel Xeon E5-2650 V2 Cooler: Some noctua cooler Motherboard: Supermicro X9 SRL-F RAM: 8 * 8GB Samsung DDR3 ECC Storage: 6 * 4TB Seagate 7200 RPM RAIDZ2 Controller: LSI H220 Case: Phanteks Enthoo Pro PSU: EVGA 650w G3
Phone: iPhone 6S 32 GB Space Grey
https://linustechtips.com/topic/996488-bad-obs-stream-quality/#findComment-11979218
2 minutes ago, PASHKA said:
YouTube
Could you send a link to one of your past streams?
PC Specs:
Freenas specs:
https://linustechtips.com/topic/996488-bad-obs-stream-quality/#findComment-11979248
Lower the GPU usage, by  capping fps to below what it's doing now. NVENC do bug out when the GPU is hitting max usage.
btw last time I used NVENC, I need to raise my bitrate to 20000 for the picture to look good. I hope it's no longer the case.
Desktop benching:
https://linustechtips.com/topic/996488-bad-obs-stream-quality/#findComment-11979273
x264 is generally far better than nvenc for stream quality (unless the bitrate is very high). Does OBS say encoding is overloaded when streaming with x264?
PC Specs:
Freenas specs:
https://linustechtips.com/topic/996488-bad-obs-stream-quality/#findComment-11979292
Pls HELP!
My rig:
Intel Optane 32 GB
Why in the world would you need 13000Kb to stream to youtube? You need to use the fine tune. Take a look here https://stream.twitch.tv/encoding/
https://linustechtips.com/topic/996488-bad-obs-stream-quality/#findComment-11980342
13000kbps is far over what YT recommends as bitrate for your upload. You should be using 7000kbps at most. And you don't really need much more than that.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/996488-bad-obs-stream-quality/#findComment-11982194
I use like 3500-4000 bitrate for my streams.  13000 is crazy.  I find 3500-4000 to be good for an ok internet speed and good looking streams.
https://linustechtips.com/topic/996488-bad-obs-stream-quality/#findComment-11982900
Thats not enough for 1080p60, if thats what OP is after. For 1080p60, 5000kbps is recommended. 3500kbps+ is good for 720p60 and 1080p30.
https://linustechtips.com/topic/996488-bad-obs-stream-quality/#findComment-11982912
