Ray tracing is indeed what enables you to also calculate/show reflections of stuff that is off screen. The answer is in your question though: cubemaps. You just roughly approximate what will be reflected. If you study your puddles in detail you'll likely see it's not a totally correct reflection. Here's an explanation specific to GTA V actually:
http://www.adriancourreges.com/blog/2015/11/02/gta-v-graphics-study-part-2
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
