4 minutes ago, Elmuchaco said:
Hi i just got a ryzen 7 2700x and i want to know is my bios updated to support it. My bother board is A320M PRO-VD/S
Since you were able to boot with a 2nd gen CPU, then yes. If it wasn't updated the system wouldn't turn on.
I wouldn't really use that motherboard with an 8 core 2700x CPU though...
Edited by Spotty
https://linustechtips.com/topic/995932-need-help/#findComment-11974664
Just now, Spotty said:
Since you were able to boot, then yes. If it wasn't updated the system wouldn't turn on.
i did not boot it curently its on 2200g i updated it and now i want to swap the cpu. Well thats all my budget so i couldnt really be picky with the mobo
https://linustechtips.com/topic/995932-need-help/#findComment-11974668
