I currently have a kingston a400 240 gb ssd and a 500gb Seagate Barracuda in my setup. My setup is powered by a nameless 500w psu. This psu already in my setup for 10 years. I just wanna add a 320gb hitachi drive into in. But there is no more power cable left .  I have still a sata cable head left which is same cable as the Seagate barracuda. So, can i connect the 320gb hdd into the sata cable ?
https://linustechtips.com/topic/995805-hddssd-power-question/
You should be able to attach a splitter and just connect both drives, but I personally would never trust a 10 year old power supply.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/995805-hddssd-power-question/#findComment-11974106
You should replace the PSU.
https://linustechtips.com/topic/995805-hddssd-power-question/#findComment-11974146
I agree that you should replace the PSU. Any PSU from ten years ago is not as well made as the better ones today are. The PSU i one of the most critical compnenets in a comnputer since, if they fail, they can fail catastrophically, either catching your computer on fire or frying all your computer's components.
Jeannie
As long as anyone is oppressed, no one will be safe and free.
One has to be proactive, not reactive, to ensure the safety of one's data so backup your data! And RAID is NOT a backup!
https://linustechtips.com/topic/995805-hddssd-power-question/#findComment-11974459
