Help!!
So i just upgraded my pc today and i put a h150i radiator front mount with one top mount and bottom mounted fan and i put three fans on the outside of the case because of the 1080ti. I can not get the front filter on and i know that people have modified their case in order to get the front filter back on. Anyone do this if so how did you get around the front air filter problem! I have heard that you can cut the plastic mesh out but i still can not get the bottom to clip in.
https://linustechtips.com/topic/995787-help/
