Hi guys,
i use a NUC7I5BNH  with 16 GB of Ram and a m.2 SAMSUNG MZVPW256HEGL as a htpc since it actually has had no problems with 4K Footage.
Couple of weeks i noticed that my nuc got louder and louder. I monitored the temps and i discovered that the nuc got extremly hot (the cpu was in the high 60°C - from 64-68°C) with no load just idle.
Then one day - i was just running spotify - i had an automatic shutdown because the nuc reached critical temps.
I searched the net and didnt find much information (beside the usual 'nuc's are loud' and so on).
Well i tried everything software wise (changing bios-settings and monitoring cpu and gpu usage).
Nothing really helped.
so i disassambled the little guy and well - not even a year in use - and right between the fan and the copper cooler was a pretty noticeable dustcollection.
I cleaned it out and while i was on it i also changed the thermalpaste (had something from noctua lying around).
And see - we are now chilling again between 40°C and 60°C depending on the load.
so if anyone has some overheating trouble you should also think of cleaning the coolerassembly.
I had to dismount the cooler to get to the dust and clean everything out but with this nuc model its not that big of a challange.
i thought i'd share my experience with u in case anyone has similar troubles.
Cheers
https://linustechtips.com/topic/995637-nuc7i5-overheating-solved/
