NEED HELP WITH FIRST BUILD!
Solved by Plushellii,
I have one more question I would like help with. Some ryzen 5 series of cpu’s Have more gigahertz than some of the newer ryzen 7 cpu’s. Does that make them more powerful or not? Is there other factors that play into raw power there than threads and cores? And if one cpu has a higher total gigahertz than another cpu does that make it more powerful? Thank you very much for any help provided!
