How to bypass surveys?
ViruZ_HUN
Hello!
I would like to download this file: http://cleanfiles.net/?5jC3xWp
But when i press download then a survey comes up. How can i bypass them and make the website to just download it to me?
The Surveys wants my Credit card number and i want give any of that.
So how can i bypass them?
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
Try opening the source code and search for the referring download link and copy it to the URL.
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
wait a sec, can you tell em exacly where?
Aren't those thing usually viruses anyways. The person who made that just gets money from people trying to download this as far as I understand these
Stock coolers - The sound of bare minimum
well the video it came from ahve only likes and good comments.. i am sure that i am trying the right thing, i juts want to bypass this damn survey
Well it could work I guess, tbh I don't know if war thunder lions are popular or not.
But I have tried to download one of these for some game I can't remember, but after I downloaded it was a virus
well, its my problem if its a Virus. I want to bypass the survey!
Ctrl + u (view source) and try to find the link.You probably won't find it because the people who made surveys are smart and it(the survey thing) is a javascript app.You can disable javascript and I remember that worked,but only on very few sites because the javascript app itself gave away the link,and not the website.
@Nineshadow
Javascript found these?
What shoud i do?
This site is too fancy, they do checking on their servers to see if you have completed a survey when serving the download, if you haven't then the server does not give you the file. For the record the download URL should be: http://cleanfiles.net/df.php?id=116710
But as you can see, its not serving the file, as you haven't completed a survey.
Arch Linux on Samsung 840 EVO 120GB: Startup finished in 1.334s (kernel) + 224ms (userspace) = 1.559s | U mad windoze..?
They've implemented something to lock their content. It'll be pointless if it's bypass-able so easily.
You're better off looking for mirrors.
