Hello guys recently I installed gtx1050ti in my pc and I have an non hdmi display with vga dvi and display port. So I decided to take dvi cable next day so till then I tried to connect the pc with vga to VGA cable to the motherboard  but it did not get detected.
So what should I do please help
https://linustechtips.com/topic/994779-display-not-showing/
Someone correct me if I'm wrong, but you might need to change it so integrated graphics is default in your BIOS.
Current Build:
CPU: AMD Ryzen 5 2600 // Mobo: Ryzen AM4 B350 GAMING PLUS ATX // RAM: 16GB Corsair Vengeance LPX DDR4 3000MHz // GPU: Gigabyte AMD Radeon RX 580 Gaming 8GB // SSD: Kingston A400 120GB // HDD: 3 x WD Blue 1TB // PSUCorsair 650M // Case: Corsair 450D // Monitor: LG Ultrawide 29" IPS
Plex Server:
CPU: AMD FX 8350 Black Edition // Mobo: Gigabyte - GA-78LMT-USB3 R2 Micro ATX // RAM: 16GB Corsair Vengeance DDR3 1600 MHz // GPU: GeForce GTX 670 // HDD: Seagate BarraCuda 2TB // PSU: Kolink Core Series 500W 80 Plus Certified // Case: AVP Viper Mini Tower
Other:
PS4 Pro // PS3 // Nintendo Switch (Pokemon edition) // Nintendo 3DS // Xbox 360 // iPhone 8 Plus // Macbook Retina 2013
https://linustechtips.com/topic/994779-display-not-showing/#findComment-11964637
But bro I didn't connected vga cable to graphics card but to motherboard the normal display wasn't there
https://linustechtips.com/topic/994779-display-not-showing/#findComment-11964744
So you've got your GPU in the PC and you're connecting your monitor to the motherboard?
If I'm not mistaken, and this is what you're doing, the GPU will be set to default graphics in your BIOS, so when you're connecting to the motherboard it won't display anything. So you'll need to go into your BIOS and change the default graphics to on board.
Sorry if I'm misunderstanding your question.
Current Build:
Plex Server:
Other:
https://linustechtips.com/topic/994779-display-not-showing/#findComment-11964797
What if I connect to gpu then will it show the display?
https://linustechtips.com/topic/994779-display-not-showing/#findComment-11964817
Should do.
Current Build:
Plex Server:
Other:
https://linustechtips.com/topic/994779-display-not-showing/#findComment-11964824
