What is the difference between these?
Solved by Corsair Nick,
5 hours ago, FadedCrown said:
There are some key differences between K70 LUX and MK.2 keyboards. MK.2 took all the features from the flagship K95 Platinum and put them in a K70 form factor.
- Hardware Playback - (3) lighting and remap profiles can be saved to the keyboard, and used without the software running
- Programmable RGB Logo at the top
- Revised Media Keys - More pronounced and easier to press; similar to the K95 Platinum RGB
- Cable Management X Channels on the back - route mouse or headset cables under the keyboard to the corners for a cleaner battle station
All of the standard MK.2 keyboards use the Cherry MX switches as the LUX models. A Brown switch on the MK.2 will be the same look and feel as a Brown switch on a LUX, and so on. Let me know if you have any questions about either of the keyboards, and I can help you out.
