This is my first build, can you see any obvious errors or changes?
PCPartPicker part list:
https://linustechtips.com/topic/994393-first-build/
Looks decent. If you planned on overclocking, don't expect much from that motherboard.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/994393-first-build/#findComment-11961389
you could have gotten the asrock master sli/ac x470
it has wifi already and its good for future upgrading
₵₱Ʉ     ł5 8600₭
mσthєrвσαrd     αsrσck z370 kíllєr slí/αc
PSU     Rosewill CAPSTONE 550M
D҉i҉s҉p҉l҉a҉y҉(s҉)     B҉e҉n҉Q҉ V҉A҉ L҉E҉D҉ E҉y҉e҉-c҉a҉r҉e҉ M҉o҉n҉i҉t҉o҉r҉ 2҉2҉ I҉n҉c҉h҉
ᶜᴼᴼᴸᴵᴺᴳ     ᶜᴼᴼᴸᴱᴿ ᴹᴬˢᵀᴱᴿ ᴹᴬˢᵀᴱᴿᴸᴵᵟᵁᴵᴰ ᴸᴵᵀᴱ 120 ᴬᴵᴼ
κεψß⊕αrd     gεηεrïς uηηαmεd ςhεrrψ mx ßレuε ƒακε mεςhαηïςαレ κεψß⊕αrd
MƠƲƧЄ     ƦƛȤЄƦ ƇӇƦƠMƛ ƊЄƛƬӇƛƊƊЄƦ ЄԼƖƬЄ 2017
ѕoυɴd     eѕтoɴe вeѕт coмpυтer ɢαмιɴɢ нeαdѕeт нeαdвαɴd wιтн мιcropнoɴe мιc хιвerια v10 нeαvy вαѕѕ ѕтereo ɢαмe нeαdpнoɴe wιтн lιɢнт ғor pc ɢαмer
ФPΞЯДΓIИG SУSΓΞM     ЩIИDФЩS 10 БЯФ
https://linustechtips.com/topic/994393-first-build/#findComment-11961394
hey can you send the pc parts picker link
₵₱Ʉ     ł5 8600₭
https://linustechtips.com/topic/994393-first-build/#findComment-11961404
You quoted the list, it's all links.
Primary PC:
PSU tier list
https://linustechtips.com/topic/994393-first-build/#findComment-11961421
this better
₵₱Ʉ     ł5 8600₭
https://linustechtips.com/topic/994393-first-build/#findComment-11961451
2
I'll have a look, I'm on a tight budget so if it's cheaper that would be great
Not really. If I did I wouldn't want to go up too much anyway so it should be fine.
Thanks all for the advice.
https://linustechtips.com/topic/994393-first-build/#findComment-11961452
I’m only really using it for school work and basic 3D design in fusion 360
9 minutes ago, Yous3f_M said:
Can I ask the advantages of those changes?
https://linustechtips.com/topic/994393-first-build/#findComment-11961485
1 minute ago, hiitswilliam said:
You need to put in a graphics card if you wan't to be doing anything more intensive than watching videos.
I would think something like a 1060 6GB or a 1070 would go great with that build. They are both great value cards.
you're wrong here. the 2400g has pretty good intergrated graphics. and I think that's a bit too much for the budget here. But I sure like to hear differently so I can wide up my build i'm making
https://linustechtips.com/topic/994393-first-build/#findComment-11961490
I would think that any gaming would need a graphics card. You definitely wouldn't be able to get that great of frame rates, although it might be fine for light gaming. And graphic design would be absolutely fine.
https://linustechtips.com/topic/994393-first-build/#findComment-11961501
believe me, look up some bechmarks. it's pretty good actually. but there's nothing wrong with a gpu in the build
https://linustechtips.com/topic/994393-first-build/#findComment-11961508
it will go above his budget i tried an 1050 and 1050ti it was over his budget
₵₱Ʉ     ł5 8600₭
https://linustechtips.com/topic/994393-first-build/#findComment-11961509
https://linustechtips.com/topic/994393-first-build/#findComment-11961511
5 minutes ago, LukeSavenije said:
tbh, there's things I'd rather spend the £100 on and I don't really need the extra performance. I'm upgrading from a dual-core Celeron so this is a massive jump up. I also don't need much storage - I keep everything in the cloud so I'd rather have the SSD performance on everything that is locally saved.
Thanks though
https://linustechtips.com/topic/994393-first-build/#findComment-11961532
Thanks though
this better though
₵₱Ʉ     ł5 8600₭
https://linustechtips.com/topic/994393-first-build/#findComment-11961545
Is there a large advantage to that motherboard? I'm in the UK and it's about £30 more. What about the RAM? I can't say I've really heard of Team much - I'd like to know it works and that I can get support if it doesn't. It's my first build so having it easy would be great
https://linustechtips.com/topic/994393-first-build/#findComment-11961567
