Hey folks!
So I'm trying to wrap my head around the concept of programming through an interface.
I stumbled upon the idea in a Java Swing Tutorial, but its flying over my head to be perfectly honest.
I don't really understand it and the sources I've found through google either overexplain to the point of confusion or underexplain.
Can someone point me to a good source or provide a concise example?
Thanks in Advance!
https://linustechtips.com/topic/994083-java-interface-based-programming/
// Interfaces
// Interface declaration syntax
// <access-level> interface <interface-name> extends <super-interfaces> {
//     // Constants
//     // Method declarations
// Example - Food:
public interface Edible {
    public void eat(); // Any class that implements this interface, must
                       // implement this method.
public interface Digestible {
    public void digest();
    // Since Java 8, interfaces can have default method.
    public default void defaultMethod() {
        System.out.println("Hi from default method ...");
// We can now create a class that implements both of these interfaces.
public class Fruit implements Edible, Digestible {
    @Override
    public void eat() {
    @Override
    public void digest() {
// In Java, you can extend only one class, but you can implement many
// interfaces. For example:
public class ExampleClass extends ExampleClassParent implements InterfaceOne,
    InterfaceTwo {
    @Override
    public void InterfaceOneMethod() {
    @Override
    public void InterfaceTwoMethod() {
This example comes from learnxinyminutes, but both a brief introduction and in-depth explanation are provided by Oracle.
Interface can also use this way in java 8 and later through lambda.  This is new however and I have yet to see any java programmers ever do things this way except when they wish to be lazy and write some quick code.
class Example{
	public Example(){
    	// passing in a function to a doStuff method using lambda
    	this.doStuff(()->System.out.println("What ever doStuff is gonna do"));
    // this is a functional interface
    @functionalinterface
	public interface Function{
    	public void execute();
    // a class method that will take in a Function interface and exeute its one and only abstract function
    public void doStuff(Function function){
    	function.execute();
Sudo make me a sandwich
class Example{
	public Example(){
    	function.execute();
ouch... brutal for starter like him my friend?
I wouldn't say I'm a starter, I've done programming work for actual work, and through school for 4 years, its just I've never seen this style/approach to programming.
I know what an interface is but we were never tasked with actually creating them.
Thank you guys for your help!
